“site is currently unavailable message showing
I am humbled to be using Binverse, a software that is available online. However, many at times when I want to open the site a text comes on my screen that goes “site is currently unavailable. It is under maintenance”.
Answered By 55 points N/A #104037
There might be two possibilities in this case. Either the site that you are trying to browse is closed or is under maintenance or there is something wrong in the Binverse.
  1. Update your .Net fix from Microsoft.
  2. Consider getting the latest version of Binverse.
  3. Reinstall the version you currently have or use the latest one as I suggested.
Sometimes the Binverse server is fully loaded with requests so it is unable to perform your specific request that is why it shows that the site is currently unavailable. As per suggest by Binverse itself, you should wait 5 minutes approximately before trying again.
If the problem persist, contact the binverse support team because no one has address any solution other than these for your problem.
