karengsam
10 points
Posted on - 12/09/2012
I formatted my hard disk to Windows 7 Starter.
After doing so, I browsed to Device Manager and found the yellow exclamation next to my NIC device (Realtek RTL8139 Family PCI Fast Ethernet NIC).
Please provide me site for local area connection drivers download.
Thanks!
Site for Local Area Connection Drivers Download
Hello Karengsam
The driver you are looking for is one used quite often and should be easy to find.Â
If you do have a problem i would visit the website of the manufacturer of your laptop or if it is a desktop the manufacturer of your Motherboard.Â
They normally provide all the drivers you need in different versions.Â
Have a great one and i hope you get it fixed soon.
Hi
PQservise partition is a hidden partition that is used to do a factory reset/restore.
It can be launched by a key combo on boot (normally Alt + F10) or from e-recovery if you have formatted both the other partitions yourself this 10GB partition is not necessary but good to have if you would ever like to do a factory reset/restore.
It is normally a feature of the acer brand of laptops. Â
Have a good day.
