Site Map is not configured correctly
Hello
I just downloaded and attempted to install Site Map but I got the following error message when I try to use it. You can see the attached image error message so please help me to fix the following error ASAP. I did as mentioned in the message but could resolve the problem. Provide a suggestion to resolve it. Thanks.
Site Map Error
The customized site map could not be used because it is configured incorrectly.
The default site map has been applied instead.
To resolve this issue, repair the customized site map and it again.
