Size is getting smaller and smaller
Hi. What are the dimensions of Elecom's Bluetooth and keyboard device?
Is it battery operated?
Thanks
Thanks
The dimensions of Elcom’s Bluetooth and keyboard device is different when it is folded and different when it is open.
When opened its height is 319.2 mm and its width is 102.9 mm and it has a depth of 9.6 mm.
In folded position its height is 162.5 mm and it has width of 102.9mm while its depth is 19.2mm.
Answer to second part of your question is that yes it requires batteries to operate, which you get as accessories when you buy it. It uses Alkaline batteries which give the keyboard a battery life time of about one month.
It has a weight of195g with batteries included in it.
If it is the Freedom i-Connex Bluetooth Folding Keyboard from Elcom, this device supports iPhone, iPod touch, iPad, and other Smartphones. It features an integrated HID support that includes Netbooks, Windows Mobile 6.5, and PlayStation 3.
It can easily be setup with your smart device.
Simply pair it with your Smartphone or other smart device that supports it and that’s it, you can now begin typing with the new foldable Bluetooth keyboard. It doesn’t need other extra configuration to work.
The keyboard’s interior has high quality keys full keyboard layout that includes an extra row of six keys.
These additional six keys located on the left of the keyboard provides you direct access to functions, in different orders: fast reverse, sound up, fast forward, sound down, pause and start, and the Apple Home key.
It also works on other devices that supports HID Bluetooth keyboard like PlayStation 3s, Netbooks, UMPCs, personal computers, and more. The Freedom i-Connex Bluetooth Folding Keyboard is powered by two “AAA” size batteries and is priced at £42 on the product’s own online store.
