Size Limit Exceed Error Occurred
I have a problem with texas holdem application. I can’t understand the error message. What does this mean? Any help or idea that you can suggest for me to be able to fix this kind of error? I pasted here the error which says that there is an error with the size. Thanks in advance for your help.
Size error
Table is too big, press OK to resize riomaggiore, No limit Taxes Hold’em, denaro reale (E0,02/E0,05) [ID=R5-46292945-221] to max allowed size. Debug: client height=1002
Answered By 0 points N/A #174631
Hi Wallace D Woolard,
That error is a looping error and you cannot rid it to play the game, your files is being altered and cannot be opened by Zynga offline files anymore, what you can do is that you delete all the history and cache memory of your offline files and browsing files, and then reopen the application so that you can download another set of files that you have saved to their server, the game will work now. Cheers!
