Sizing up of the Screen of iPhone 5
Apple iPhone 5 would have a bigger size of its screen. Would you think it will add an advantage over the Samsung S3?
Hi
Apple’s iPhone 5 and the Samsung Galaxy S3 are both good phones that will be released this year. However there are a lot of speculations regarding the screen of iPhone 5 since apple is still not releasing any information about the screen of iPhone 5. Last May, The Wall Street Journal says that the device will be a 4 inch display. If you will compare it with the 4.8 inches display of Samsung Galaxy S3, it will have a big difference.
As a buyer, the screen is not the only feature of the phones; there are a lot of features and a lot of things to consider in buying a phone. For now, it’s clear that the Samsung Galaxy S3 has a bigger edge compared to Apple iPhone 5.
Hope you will find this helpful.
Cheers
