Skin creator for Prototype Games
Hello Gorge Rutil,
If you want to do some of the graphics world in 3D then you have to use the 3DMAX. It is one of the best software for making 3D animation of graphics. But you can also use Adobe techniques for making animation as they also have a good name in creating animations and graphics on the market. I Prefer you the above two software for graphic production.
For skin creating you have to use (Skin Creator 5.8.5.3718) version of the software to make beautiful and exciting skins and you can use them anywhere you want. Here is the downloading link of that software and you can get it free of cost from there.
Try Microsoft SketchFlow. Try to create working prototypes according your specifics. The skin of the prototypes is pencil-sketch style to show that the prototype is just a prototype and not a complete application. But if you just want to find out what it will look like then you can also WPF design. Some other options would be:
