Skype app doesn’t allow to login but site does.
When I am using the Skype Software, it needs login into the account. So when I try to login from the Skype Application it does not allow me to do this and when I tried the same Username and Password combination on their site, the site allows me to do login successfully. So please suggest me some solution that how to resolve the issue??
Answered By 0 points N/A #200017
Hi Coshaun.
I had the same problem once. I could go from android and site, but not from a PC. This actually occurs when your Skype version is backdated. It fails to reach all the credentials to log in. You can download the most recent one free from the Skype official site. Go and download, after downloading go to Skype site and change your password once. Finally, go into Skype software and use your new password and it should work fine.
