Skype error with operating system availability
Hi experts,
I have this weird error from Skype. This morning this error message appeared and it says that Skype is no longer available for my Windows 7. I have checked the website and Skype is still available for Windows 7. Can anyone help me please to fix this error ? What could be the problem ?
Thank you !
Skype is no longer available for your operating system.
To use Skype, sign in to your account from one of the supported systems.
Find out more about supported systems
Answered By 0 points N/A #178426
The problem is not with the windows, The problem is with your Skype version. You have not specified the Version you are using for windows 7. You should try updating the latest version and check if the issue persists. While installing the new Skype make sure all the registry is clean and temporary files are removed.
Also try to turn off the compatibility mode with the old version of windows.
Good luck..!!
