I’m using Skype since a long time now but suddenly this error is popping up. Does anyone knows what thus error means? I’m really confused. Is my app having troubles? This is a new computer I bought. Is it possible that my computer is not supporting Skype?
Skype EXE Bad Image Error Showing
Bad Image error is a mistake which comes up when Windows can’t run the projects you took a stab at running principally because of the documents and libraries expected to run the program are adulterated because of an update. Each rendition of the Windows Operating System beginning with Windows 8 is designed to consequently check for, download and introduce accessible updates every now and then.
Be that as it may, here and there, introducing explicit Windows updates can prompt various types of issues. One of these issues is the (name of application).exe – Bad Image mistake message that begins seeming all the time after either downloading and introducing an imperfect update for Windows or refreshing a Windows PC to an emphasis of Windows 8/10 that has the damaged update pre-introduced.
