Skype Extras Manager – Unexpected response from server received.
Hi guys,
Have a look at the message below. It is a message indicating confirmation.
But I do not understand the unexpected response. If you have any idea regarding this issue, please help me.
Confirmation
Unexpected response from the server received.
Do you want to send a problem report to customer
support service?
Best Answer by Aquino Meman
Answered By 30 points N/A #156815
This type of problem from the server side may be due to the unresponsive server or crashed server. Try sending the error report to the customer care and see the response for exact report. If you are facing the problem regularly then uninstall Skype and install the new copy.
To download Skype click on the below link.
https://www.skype.com/en/get-skype/
Thank you.
Answered By 50 points N/A #156816
Hello Zadok,
Maybe the problem of this failure is in your skype program. Try to use a new skype version and try if the problem will occur again. Uninstall first your old skype version and install a new one. I will give you a link to download a new skype version, click the link below.
