Skype installation issue with Touchpad
Hello, I have a TouchPad and I installed Skype, but how come that I could not view my friends and why is it they can see me? Even though, I know that the features is not good. However I can listen to them yet couldn't view them. Is there someone encountered this similar issue and knows how to fix it? Thank you.
Answered By 10 points N/A #122090
You should check the skype settings and make sure that you have turned the visibility on. The visibility in this case is for you to be able to  be seen by your friends. May be that option is disabled in your skype. Another mistake you might be making is making an audio call to your friends. They might be seeing because they pick the call as video call on their end, but since you have made the call as an audio call on your end then you will not be able to see them.
But generally the features of skype on some touchpads are not that good, and therefore you can just restarting the device. Maybe it will work well after the restart.
Regards
Thompson Locker
