Skype phone calls on android via bluetooth?
I have the Samsung Galaxy S3 phone and the Skype app. I'd like some Bluetooth headsets for my phone.
Preferably earphones and below $20.
They should also have a mic integrated.
You have a Samsung galaxy and you installed the Skype app in it.
For swift communication through it a Bluetooth headset would help really well.
You want to buy one which is of less than $20.
Try to choose from this link.
Well,There are hundreds of options available for Bluetooth headsets. Here is the link for them on eBay
https://www.ebay.com/sch/Headsets-/80077/i.html?_nkw=bluetooth%20headset
Search them on the bases of money, Brand , Warranty and any other things that you might be having in your mind for ideal usage.
Make sure thought that the headsets you select are compatible with Samsung galaxy. Thanks!
Notifications
