Skype portable apps shows error
I just downloaded Skype Portable using Win 7 64 bits Operating System and when I attempted to install the program the pop up error message appeared. You can see the attached error image. I followed the recommendations given in attached image and reinstalled the program to fix this error but I could not get any resolution. Please help me to fix it ASAP. I would be thankful to you.
Skype Portable portableApps.com
Skype Portable cannot be started. You may wish to re-install to fix this issue. (ERROR: Skype.exe could not be found)
