Skype shows an error message and does not start.
Hi, I use Skype for web calls. For some days I am not being able to start my Skype and getting the following error.
I have restarted my PC and still getting this error message and not being able to start Skype.
Please give me a solution to this problem.
I also use a Skype phone.
Error message: Can't open Skype. You are already signed in on this computer. Please sign out and try again.
Best Answer by Kumay Edwards
Answered By 10 points N/A #156782
Hello Goldie,
To resolve that issue you are getting when you try to access Skype, you will need to follow the procedure below:
  • First of all, you will need to quit Skype in case it running right now.
  • After that, you will need to hold the Windows key and then press R on your keyboard.
  • A box will come up. In it you will need to type %appdata%Skype, and then press Enter.
  • You will have to get rid of any files that start with temp.
  • Also get rid of shared.xml.
  • And then rename the folder with your Skype name so that you have something likemyname_old
  • After that try starting Skype and see if you can sign in.
Carl
Answered By 5 points N/A #156783
First you have to kill all running files of Skype i.e. running on background.
For this Open Windows Task Manager by pressing ctrl+Alt+delete at a time.
Kill any running process of Skype.exe , close task bar (do not reboot system)
Now go to Start menu and click Run.
Type %appdata% and enter. Windows File Explorer will open up, Search a folder named "Skype", rename the folder to some other name like new_skype or old_skype.
Your call history can be reestablished as it will be in old_skype, in case.
