I use Skype on regular basis and so far it was working properly. Recently it has been showing some problems. Each time I turn it on It froze's my pc and shows no sign of recovering.
Then in the task manager I can see the message "not responding". When I close it and restart it again does the same again.
Please help me getting rid of this problem.
Dixon Chapman
Skype slowing down my pc-what to do?
I have the solution for you by using a registry cleaner can clean up your computer and then make your computer faster. The reason is that there may be some registry errors and remnant, corrupt files and temp files in your computer to cause "computer slow".
Take note that each time you install and uninstall certain software on your computer and surfing online you will create a junk in the computer registry. Over time, the registry can develop very large, especially if the different programs that you have installed were not deleted properly and/or updating its Registry entries.
There is a need to clean and scan your computer with registry cleaner to be able to make it faster again. A good Registry Cleaner dramatically improve your computer’s performance.
There are some comparison and review of TOP 5 registry cleaners.
You can download and scan your computer for free.
Thanks
If that’s the current state of the program then you simply need to reinstall it or better yet just upgrade it to the latest version. Download the free version of Revo Uninstaller and install it. Once installed, start Revo then select Skype from the list and click “Uninstall.” Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftovers.
Delete everything it finds. This will remove everything the program created on your computer. When it is finished, close Revo Uninstaller then open your web browser and download the latest Skype for Windows. The latest version supports Windows XP Service Pack 3, Windows Vista, Windows 7, Windows 8.x, and Windows 10. See if this fixes the problem.
