willyumol 0 points N/APosted on - 09/29/2011
Hello Everyone,
Good Day.
I am planning to buy a new Android Phone with 2.3 Gingerbread OS. I keep on searching the internet which phone is capable of video call through Skype mobile. Do you have any ideas? I believe Android phones with two camera's will work but doesn't know what model.
Skype Video call on Android phone is performed better you know. But will you know to operate the phone in a video call or chat. Then good one. If you ignore about make video call and video chat. You have to learn it first. Then try to buy a phone. This may very well for you.
Now I am telling you about the Android phone model for your better using: You can try to list CX3, P#2, C100 and other Multimedia formation. But the phones will not so hardy and easy for using. Get a very sharp view and care of the phones only the simple power on display and keypad might break on the phones. So decide at first which you want.
It seems you need help regarding buying an Android Smartphone and set up a Skype video call.
An Android Smartphone with 2 cameras is perfect but now Skype mobile has introduced a new feature.
In which you can Use your Back camera to start a video call. It seems awkward but that will help the people who have Smartphone with only back camera and no Front camera.
To download Skype, after you buy Smartphone go to play shop in the menu and then in the search box type "Skype” and then you will see it first in the list.
I suggest you buy Samsung Galaxy note (If you have plans for high budget phones)
Or going for low budgets Try Samsung Galaxy Ace 2 (Awesome specs, it's worth every dollar you spend on it).
If you want to buy a phone with Android 2.3 Gingerbread, you can try LG Optimus 2X. Here are the phone’s specifications. The LG Optimus 2X is a discontinued 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was announced to the public on December 2010 and released on February 2011 measuring 123.9 x 63.2 x 10.9 millimeters and weighing 139 grams.
LG Optimus 2X
It uses mini-SIM card and has IPS LCD capacitive touchscreen display with 16M colors at 480 x 800 pixels screen resolution. It is protected with Corning Gorilla Glass and ships with either Android 2.2 Froyo or Android 2.3 Gingerbread upgradable to Android 4.0 Ice Cream Sandwich powered by NVIDIA Tegra 2 AP20H chipset, 1 GHz Dual-Core Cortex-A9 processor, and ULP GeForce GPU.
It supports microSD expandable up to 32 GB. It runs on 512 MB RAM with 8 GB internal storage. The primary camera supports 8 megapixels with AF featuring LED flash. It supports 1080p video recording at 24 fps and 720p video recording at 30 fps. The secondary camera supports 1.3 megapixels.
It has 3.5-millimeter jack, Wi-Fi 802.11 b/g/n with DLNA and hotspot support, Bluetooth 2.1 with A2DP support, GPS with A-GPS support, stereo FM radio with RDS support, and microUSB 2.0. It has no support for NFC. It has built-in accelerometer, gyro, proximity, and compass sensors. The pre-installed web browser supports HTML with Adobe Flash support.
It runs on removable Li-Ion 1500 mAh battery with standby time up to 400 hours and talk time up to 7 hours 50 minutes. It is available in black color. If you want to download Skype, download Skype for Android on the Google Play store.
1....
