Starting Video Chat on Skype caused BSOD
Asked By 110 points N/A Posted on -
Hi, need help with Skype. When I go on a video call, it crashes and gave me a blue screen. I would need to restart the machine to fix the problem.
This only happens when I go to Skype video. I have updated the video driver and still the same.
I am running Skype 5.3.
Best Answer by Tabatha Sailer
Answered By 0 points N/A #88275
There's a big possibility that you might be using Realtek HD Audio Control Panel. It starts automatically when it loads to your desktop. To stop this, Go to Start > Run > type "msconfig" > Ok.
Click startup tab > locates RTHDCPL.EXE and uncheck. Restart the computer and that should fix the blue screen with Skype video.
Answered By 110 points N/A #88276
I don't have RTHDCPL.EXE on the startup tab.
Answered By 0 points N/A #88277
Uninstall the current version and install an old version. I have tried this old version and no blue screen showing up on Skype video.
The old Skype version is 4.1.0.136. Click the link below to start the download.
Tell me if this works for you.
http://www.oldapps.com/skype.php?old_skype=83?download
Answered By 110 points N/A #88278
Reinstalled the old version of Skype.
So far no blue screen on Skype video.
Thanks!
Answered By 0 points N/A #88279
Excellent. I'm just adding one possible screenshot since there are a lot of possibilities.
Windows has been shut to prevent damage to your computer
Answered By 110 points N/A #88280
Sure.
Thanks for all the help.
