I am thinking about buying a speaker for my smartphone. I would like to know more about Sony SRS-X5. Is it going to work with my iPhone S4? How much is it? How does it connect with my phone? Does it include software where I can synchronize everything? What are the available ports for this? How many speakers available? Is it shockproof? What are the peripherals included? Does it include USB connector? How’s its performance compared to any regular speakers?
A Sleek Portable Speaker that Provides Elegance and Comfort
Hello Janet!
The Sony SRS-X5 is a multimedia speaker that reiterates and redefines the technological advancements of NFC and Bluetooth technology.
It provides 2.1 channels that comprises a subwoofer and 2 front speakers. You can connect it with Bluetooth connectivity. The price will cost you $163.60.It has the hands-free calls capability, one-touch listening via NFC device. Can be connected with your android phones and iPhone. It has the transmission range of 33 feet or 10 meters. The output power is normally 20 watts. Battery hours can hold up to eight (8) hours. Supports Stereo mini-jack input and USB ports. You can recharge it also with your USB cord. It comes with AC adaptor for recharging.
