When I use my PowerPoint presentations from my laptop at church, so that my congregation is able to see the words of the songs on a flat screen TV, some of the slides seem to disappear from the computer but are shown perfectly on the TV. The sliders disappear randomly when we play the same song; it’s not always the same slide. Can you tell me why this is happening, because it makes no sense?
Slides Disappear Randomly in PowerPoint
Hi Jonathon,
I wonder if you have used a JAVA plug in perhaps a jCarousel library. There had been a known bug with using such plug in and this is related to the use of a circular wrapping. You may want to use the Slideshow’s default jQuery Cycle option.
Oddly, there are documentation talking about a certain user permission to make sure that you are indeed logged in as the administrator of the computer and disable UAC if you are using Windows Vista and later Operating systems.
