F Samuel
10 points
Posted on - 01/02/2012
We intend on changing all machines to slim clients, and transfer all operating system information to our new location. Please advise on the process of transferring information from one location to another without compromising, or even better, to improve and optimize user experience.
Slim clients, and transfer all operating system information to our new location
As for the operating systems that you are using on the old machines, I do not think transferring is the thing that you will do when you want them on the slim clients, but you will instead need to install them on the slim clients. To be able to optimize performance of the slim clients, then you will need to observe the following:
In case the slim clients are all from a single manufacturer, you will need to check which operating system they work with bet and install it.
But in case they are from different manufacturers, you will need to check each client and then make sure that the operating system that you use on it gives the best performance.
After you have installed the operating systems, you can then transfer the data from the old machines to the slim clients.
-Thompson Locker
