Adams Baker
60 points
Posted on - 10/09/2012
Hello everyone!
My SLT would not start. I have downloaded this from the internet.
I need someone who knows this application, how do I fix this?
SLT_Reverse_Directory_2011.exe- Application Error
The application failed to initialize properly (0xc0000135). Click OK to terminate the application.
SLT reverse Directory 2011: Application Error
Hi Adams,
The error you are getting is because of the .NET framework. Download the latest version of the Microsoft .NET Framework and install it. Restart your computer and run your program again. It will work.
Hi Adams Baker,
So you’re having with the Application Error. I have also experienced the same issue as yours before. It's because your framework.net outdated or your OS not have framework.net.
The problem must be fixed in several steps:
1. Go to http://www.microsoft.com/en-us/download/details.aspx?id=30653
2. Download the latest framework.net for the desktop (your OS must match with the system, it's for x86 or x64).
3. Install it.
4. Restart your computer.
5. Your application working well.
Help this solution helps you.
Cheers.
