arsidoo
Posted on - 08/14/2011
I am using Avro 5.1.0 for writing Bangla. Everything was ok until Yesterday i installed .NET Framework 2.0 in my Windows XP (sp2). And after installing it, my Bangla font become too small.
I have uninstalled the .NET Framework, reinstalled the Avro.
But there is no change .
What should i do now?
(here is a screenshot that shows the problem on my Internet browser)
Small font problem in Bangla
Hi Arsidoo,
Too small Bangla Font?
The work around to fix this:
Click Open Internet Explorer.
Click View, Text Size and adjust the Font.
Options are from smallest to largest text size.
Another step:
Use your mouse scroll, Press and hold CTRL and adjust the size by scrolling up to make the size bigger and down to re-size to small font.
This the same applies to Outlook Express.
Open Outlook Express.
Go to View, Text Size and adjust the Font
Choose your desired Font size.
The same steps to follow using your mouse scroll when changing Font size on email client.
Hello Arisdoo,
For surfing the internet, you have to install all the latest software or plug-ins, which are necessary in all browsers. Install the net framework again. It's not creating problems for the net framework. To make the Bangla font bigger or smaller, you have to do the things below:
Press ctrl or + to make the font bigger.
Press ctrl or – to make the font smaller.
Another way to make font smaller or bigger is to press ctrl or move the scroll button of your mouse up & down.
These tasks are very easy and I hope that they will be helpful for you.
