Smart case logon patch install driver
At the beginning of installation of smart case logon patch, there needs a driver to support to run the software. Where can I find a specific driver?
If the program you are asking here is a download version or was downloaded from a website, visit that website again then check it for the program’s system requirements. Search the site for any technical requirements, technical information, or the Frequently Asked Questions [FAQs] if it is possible and available regarding the application.
The information that you’ll be getting for the application’s system requirements will help you determine the correct version of the driver that appears to be missing during your installation and other important details that are required by the program.
You may also find this information on the software’s Help menu. This part of the program lists the different functions, some tips, its home page, the Frequently Asked Questions, and others. You may also try reinstalling the program.
