Smart Lock that can be access using Android phone
Hello!
I want to add security locks in my house. I want to know how to install Danalock Bluetooth Smartlock? How much does it cost? Does it works with Android and iOS? What are the system requirements? In case of emergency can bypass the security lock? How many phones are allowed to communicate with this device? How far can I access the security lock? What type of doors I can use this device? What are the parts included?
Answered By 5 points N/A #175168
Now a days security is more and more important thing and with the help of technology we can use door locks without the need of keys.The Danalock provide this door locks with affordable price around 160$. It is easy to install on your smartphones and made to fit any doors. It very simple to quick lock and unlock your door. It supports worldwide home control, log activity, multiple connection options, interaction with other systems and you can provide home access as time controlled manner.It is connected via Bluetooth and Z wave technology.
