Hello Dear Friends, I would like to know about the best software that will do smart pdf to doc convertor for mac except that of Adobe Professional.
Please do the needful for guiding me a software that can be used or downloaded for free and that will give a good result.
Smart PDF to doc convertor for Mac
There are plenty of ways you can do that:
First you can use Mac's own Automator tool to convert PDF to text document. You can find the easy steps here
Go to PDFONLINE.COM and upload your pdf file and press convert button. This may take some time to convert your file to doc. So be patient.
Use free PDF to doc converter tool for Mac. Please Google it and download the file.
Hope it works for you.
Hello, Jolie Angelinanme.
In reading PDF files to Word File in MAC OS is not that easy like what we did in Windows OS.
But now, there are plenty of designed software to convert a PDF File to read in Word File in MAC oS.
Convert PDF on MAC or AnyBizSoft PDF to Word, these are tested software to do this file conversion.
This software are available for free download. You can find it
easily in Google.
This software are easy to use and manageable. In converting PDF Files, just drag and drop to the software panel
and choose what format you want to convert the file. And you can set pages range to convert on file.
Just that easy.
But, if there is any password on the files, software will
let you know that you need to enter a file password.
Hope this advice will help you a lot.
Best regards.
