SmartAudio II application error message:
At the time of attempting to run SmartAudio II I received an error message which you can see below in the attached image:
SAIICpl
The required .NET framework is not found!
The SmartAudio II application will be terminated.
OK
Which version .Net Framework should I install to resolve this issue?
You can resolve your problem by following some steps.
- You have to download Microsoft .NET Framework 4
- Download this Web Installer from this link.
- If you still have the same error then you will have to download tool and the remove .NET
- Download the tool and remove .NET and after that again download the .NET and install it.
I am sure you will fix this issue.
Can you specify which version of .net is currently installed? I would request you to download the latest version of .net that is 4.5 sometimes the latest software’s are compatible with latest version of .net, It would be better if you see the required from the site smart audio II and see which version they want if it is the latest version then there is no problem at all, download the latest version and install it from HERE
To fix your problem you will need to uninstall Smart Audio II and install .Net Framework 3 and later. Smart Audio II doesn't seem to work even if you install the correct .Net Framework after the application is already installed. Here are the steps to follow:
Uninstall Smart Audio II.
Restart your Computer.
Download .Net Framework 3+.
Install .Net Framework.
Install Smart Audio II.
After following these steps you should be ok and everything should be running smoothly.
P Vhilary
There’s nothing wrong with your sound card driver. It’s just that the required component is not yet installed. You just need to install the required Microsoft .NET Framework and the sound card software should work properly. Because you didn’t mention what version is required, here are several you can download:
- Microsoft .NET Framework 2 Service Pack 2 – it supports Windows XP and Windows Server 2003. If you have a higher operating system, try installing it. But if it doesn’t install, your platform is not supported.
- Microsoft .NET Framework 3 – it supports Windows XP and Windows Server 2003. If you have a higher operating system, try installing it. But if it doesn’t install, your platform is not supported.
- Microsoft .NET Framework 3 Service Pack 1 – it supports Windows XP and Windows Server 2003. If you have a higher operating system, try installing it. But if it doesn’t install, your platform is not supported.
- Microsoft .NET Framework 3.5 Service Pack 1 – it supports Windows XP, Windows Vista, Windows Server 2003, and Windows Server 2008. If you have a higher operating system, try installing it. But if it doesn’t install, your platform is not supported.
- Microsoft .NET Framework 4 – it supports Windows XP Service Pack 3, Windows Vista Service Pack 1, Windows 7, Windows Server 2003 Service Pack 2, Windows Server 2008, and Windows Server 2008 R2. If you have a higher operating system, try installing it. But if it doesn’t install, your platform is not supported.
