I have lots of network computers and I have to put security using my smart card reader ICE 5700 Plus, I used it on my Windows 7 Client and it works fine when I installed it. When I logon to the system, it asked me about certificate? Where do I find the certificate asked by the computer system?
SmartCard Certificate Allows SmartCard Modification
Hi pia, actually there are some of the software which must require some of the remaining items like a program that updates text file, manipulate file, registration key, name key certificate etc. so here he same case is with you and for this there is only one path and that one is the internet. You can search out the files of certificate on the World Wide Web or the other one solution for you is that you can download or install again that file by the new source and try to download that file which has two possibilities i.e. it poses a certificate built-in or there is no any need for any certificate.
