I have Hauwei Ascend P7 which is having poor video play back, the audio is okay but videos appear frame by frame, like they are being read off a scratchy DVD, how can I get them playing okay? because I got the same videos from a friend and they were playing okay on their phone? what could be the problem?
Slow Video performance can be contributed for multiple reasons like low internal free memory (RAM:- Random Access Memory), low available processing speed owing to number of running processes. If you are trying to play the video from the internet directly then it could be owing to poor bandwidth availability with your ISP (Internet service provider).
Assuming that you have the video within your phone memory, the internet connectivity issue can be ignored. Ensure that the video is not stored within phone internal memory, if so, then transfer the video to your external Sdcard storage. Open settings and go inside Applications section and verify storage usage. Any other application residing in phone memory should be transferred (If possible) to the phone external storage. Also, check for running processes, any unused running application (other than system applications and antivirus) should be closed. All this should essentially increase your phone memory and available free memory, which gets used during video running.
Also make sure that you reboot your phone at least once each day as android phones consumes lots of memory and a restart often resulted in boosting performance.
The Huawei Ascend P7 is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was unveiled to the public on May 2014 and released on June 2014 measuring 139.8 x 68.8 x 6.5 millimeters and weighing 124 grams. It uses micro-SIM card for the single SIM model and micro-SIM/nano-SIM cards for the dual SIM model.
Huawei Ascend P7
It has IPS LCD capacitive touchscreen display with 16M colors at 1080 x 1920 pixels screen resolution. It supports multi-touch protected with Corning Gorilla Glass 3 with Emotion UI 2.3. It runs on Android 4.4.2 KitKat upgradable to Android 5.1.1 Lollipop powered by HiSilicon Kirin 910T (28 nm) chipset, 1.8 GHz Quad-Core Cortex-A9 processor, and Mali-450MP4 GPU.
It supports microSD expandable up to 64 GB for the single SIM model. The dual SIM model doesn’t support microSD. It runs on 2 GB RAM with 16 GB internal storage. The primary camera supports 13 megapixels with f/2.0, 28mm (wide), and AF featuring LED flash, HDR, and panorama and supports 1080p video recording at 30 fps. The secondary camera supports 8 megapixels with f/2.0 and 26mm (wide).
It has 3.5-millimeter jack featuring Dolby Digital Plus audio enhancement and active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n with dual-band, Wi-Fi Direct, DLNA, and hotspot support; Bluetooth 4.0 with A2DP and LE support; GPS with A-GPS and GLONASS support; NFC; FM radio; and microUSB 2.0 with USB Host support. It has built-in accelerometer, proximity, and compass sensors. The pre-installed web browser supports HTML5.
It runs on non-removable Li-Po 2500 mAh battery with standby time up to 422 hours on 3G and talk time up to 22 hours on 2G and 14 hours on 3G. It is available in black, white, and pink colors. Now, if images appear like frame by frame when playing videos, try updating your media player. Your phone’s built-in media player supports XviD, MP4, H.264, and WMV video formats.
1....
