While looking for smile pack creator, I found that it has support for several operating systems; Windows vista, Windows XP and several others.
Is there a version that I can use on my Linux based operating system?
I am using suse Linux distribution.
Smiley pack creator support in linux operating systems.
I'm sorry but there is no native version of smile pack creator for Linux. But as any application you can use windows version and run under WINE emulator in Linux. So to install WINE go to software center and search for WINE and install it.
After installation download smile pack creator installation file, right mouse click on it and select WINE application loader option, after that step installation is same as on Windows machines.
