The snap-in is not created
In my Disk Defragmenter Program I am having a critical problem.
The screenshot attached below says details about the problem. The error message is;
“Snap-in Creation Failed.
The snap-in is not created; it may not be installed properly.
Name: Disk Defragmenter
CLSID:{43668E21-2636-11D1-A1CE-0080C88593A5}”
I don’t want to reinstall the windows. It’s for me troublesome. Is there any alternative way?
Please help.
Answered By 0 points N/A #128448
In that case there is other alternative solution to resolve your problem as I go search in the net. As my experienced I’ve never encountered such that problem. I can’t provide you with my own tutorials. So what I’m going to do I’m helping you through searching on the net so I found this website that can help you that does not need to reinstall again the windows. Here is the site http://www.andreasroom.com/blog/archive/2004/01/18/defrag.aspx
Hope it will help a little.
Regards
