Louise Rios
10 points
Posted on - 11/16/2012
I have a spider elite Wanadoo edition game on Xbox 360. I wonder if this fits here but anyway it's a software and perhaps there are gamers here and hey! It's Xbox by Microsoft. It freezes just like a computer. It does not work at all.
Sniper Elite wanadoo edition help
Hi Ross,
Does this happen when playing Sniper Elite alone or when playing other games as well? If it happens with other games too, it means your Xbox 360 is getting too hot. To solve this, move the console to a well ventilated place, away from other devices. It's important to keep your Xbox in a cool area.
If this happens with Sniper Elite alone. Then it's probably the software that's the problem. It may not be compatible with your Xbox 360 or it may be damaged. You can uninstall and re-install the program. If this doesn't work, you may have to uninstall the one you have and get another version of the software.
Hope this fixes the problem.
