Snipping Tool For Windows 8
How to access and use the Snipping tool for Windows 8 to take a snap of any part of your Computer screen by not using the ‘prt sc’ button on the keyboard?
Take the cursor to the Right side of your screen. You will find a Search option.
Search for ‘Snipping Tool’ which is already installed in the System. And click on the ‘Snipping Tool’ option.
The following Window will open-
Now you can Click on the ‘New’ option to snip any part on the current screen by dragging the plus cursor on the desired area.
The part dragged will appear in the ‘Snipping Tool’ Window. Then you can copy paste the resultant snap or you can even save the image.
