Snipping tools capturing app in win7
Hi i want to save steps of my computer networks labs while doing practice which tools will be helpful other than snipping tools?
You can use Snagit, one of the best screen capturing tools in the market. It is able to record screenshots as well as the whole video of the session.
If you do not wanted to mess up with any third party software then, you can use PSR, a built in utility in Windows 7. Just do the following to get it,
START > RUN > type psr and press ENTER.
A dialog box will appear click on Record to start recording.
Greetings Densiehope,
While doing practice, you could save the steps on your computer network labs by using software such as :
Hope this help.
Stonjhon Llison
