Snipping Tools For Windows 7
What is the procedure to find and use Snipping Tools for Windows 7 for snipping only a small part of the page without taking the screenshot of the whole page?
Whenever you wish to snip off any part of the Window for any further use, simple follow the following steps!
1. Press ‘Start’ button on your Desktop.
2. In the ‘Search’ tab search for the ‘Snipping Tool’. Once found, click on the ‘Snipping Tool’ option.
3. The following Window will open-
4. Now, click on the ‘New’ option. A ‘+’ cursor will appear and the screen will fade. You have to just drag the ‘+’ cursor and select the portion to be snipped.
5. Once you release the cursor, that part will be snipped and will appear on the ‘Snipping Tool’ Window. It is now ready to be copied or cut and pasted wherever you wish to, or you can just save it as an image.
