Paul Lewis
Posted on - 12/08/2011
My systems specifications are Imac C2D 2,4 ghz / 2Go ram / Snow Leopard /Socialite 1.3.5
Permissions rebuilds. But I don’t know why my socialite has suddenly started giving me an error today and it just surprised me. Everything seems is working great but when after every time I refresh, a black window appears showing me an error saying
Twitter Error“
Error : Twitter error,An unknown error has occurred.”
I have given the short picture of the error.
Socialite error in IMac C2D
This you must do first just simply you need to remove or uninstall the present Twitter service and then try to reinstall again from your computer so that it can allow the new permission from the computer and then try this one just simply check the software if its compatible to your unit or maybe try to scan if its infected an viruses or maybe an spyware just simply try that one to avoid any error or maybe problem from your software and then the Socialite will read the access to the Direct messages it can be allow or work only from the 1.3.5 approves properly in the new Twitter system from your computer.
Ben
