ann tanner
20 points
Posted on - 07/17/2019
I use QuickBooks software for my business. It started throwing socket error 11004 QuickBooks pos errors while handling credit card transactions or handling user receipts. How am I supposed to go past this error?
Socket Error 11004 Quickbooks Pos Solved
The QuickBooks software is widely used by small businesses to handle small transactions and handle customer receipts, and so on. The socket error sometimes occurs when the client is unable to connect to internet servers.
These issues can generally be resolved by using one or more than one of the following methods. First, reboot your computer and try again. This should solve the problem in most cases. If this doesn’t work, then reset your internet connections and check all cords. Further, check your system’s time and date settings. Resetting or correcting them might also do the trick.
