I have this error when I want to open Report Software and it something about an XML document. I don’t know what could be the problem with this. Any solution ? What is causing this error message ? Should I be worried ?
Thank you !
Configuration Manager
There is an error in XML document (1,73402).
Details>>
OK
Software 07B computer that recently used a specified executable program
This error is likely a result of missing, incorrect, or flawed information within a particular file. It could also be a result of a corrupted file. You can either examine the particular file for errors or you can attempt to repair the file using tools provided by the software you are using. It may also be the result of software in need of maintenance or an upgrade. Conduct software upgrades and system maintenance.
