Software adobe flash player builder and game development
Hello Techyv Friends,
I need to know more about software adobe flash player builder and game development.
Will it support ActionScript language, please do let me know.
Thanks, Adam Johnson
Hi Adam,
'Adobe Flash Player' is a multimedia and software program used for authoring vector graphics. The applications can be programmed using object oriented language called 'Action Script'. It uses classical Java class model for programming. It makes the Flash content accessible on various computer systems and devices.They can be used as plug-in for smartphones and tablets.
The Flash Player files are in 'SWF' format. The vector graphics combined with the program code makes the files smaller. As a result these files require less bandwidth. The flash videos are free and can be used as plugin and are cross platform independence. It is useful for creating web applications, games and movies, content for mobile devices.
