Hello expert,
My internet speed seems too low for the last couple of days and I informed my network operator about this issue but he said that they have no problem with their server speed.
But my internet connection remains slow.
I need to check my internet speed.
Is there any software to analyze net speed ?
If please send me the download link of that software.
Software to analyze net speed
Greetings Matthew E Davis,
Well you can check your internet speed on various websites there is no need to download any software.
Check out the following websites:
SPEEDTEST Ookla Speedtest
BANDWITH TEST.
This is also java one AUDIT BANDWITH TEST.
Speedtest is probably the best though, at least in my opinion.
Hope this helps you,
Regards.
Checking your internet speed test online is the simplest way to test the internet speed. The result will be accurate showing both download speed and upload speed.
If you need a software for testing your internet speed, download Internet speed tester software from the Internet that is available for free of cost.
Hope this will be helpful for you to test the internet speed.
