I want to work with PHP. So, I need to software to do it. What is the best PHP editing app? Oh! One thing, it should include live preview. Please, help me giving enough information in this regard.
Thanks
Software and information for editing PHP application
HTML-kit Build 292 R2 is a lightweight full featured editor and IDE that has support for HTML, XHTML, CSS, XSL and XML. We can edit, preview and publish web page. It has support for java script and VB Script, ASP, PHP, Perl, Python, VB, Java, Ruby, C/C++, C#, Java and Delphi as well. It provides a user friendly environment and is easy to use. HTML Kit includes internal, external, server-side and live preview modes. It provides FTP workspace for uploading, downloading and live editing of files.
If you want to work with PHP and looking for a good editor, the best that I’ve used is Notepad++. It is a free source code editor and Notepad replacement that supports tabbing. You don’t need to open a new instance of Notepad++ for every file you need to open.
Files are opened by tabs. This means when you open a file, it will appear on the next tab. If you have several files opened, you will have several tabs in Notepad++. The program can be used on any programming languages not only PHP. It supports syntax highlighting which is very useful when you are editing HTML tags and JavaScripts.
Notepad++ supports Windows 2000, Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10. Now, if you want a platform where you can run the PHP file for testing, you may want to check AMPPS. It is a software stack from Softaculous which allows you to use Apache, Perl, Python, MySQL, MongoDB, PHP, and Softaculous auto-installer on your desktop.
This includes everything you need in developing a website. AMPPS supports Windows XP Service Pack 3, Windows Vista Service Pack 2, Windows 7, Windows 8, and Windows 10 including Windows Server 2003 Service Pack 2 or higher, Windows Server 2008, and Windows Server 2008 R2. If you are using Microsoft Windows, check the download first because there are two download links for Microsoft Windows.
The download link for Windows XP and Windows Server platforms are separate from Windows Vista and higher.
