Finlay
50 points
Posted on - 08/31/2012
Hey I am being having problem with decoding dvd that I am supposed to burn. I have tried several free software but I am failing. Any of you does have experience of decoding dvd and help me by sharing the procedure please?
Software and Procedures on Decoding DVD for Burning
Hi there,
Best and 100 % free tool to decode and burn a dvd is Any Video Converter from AnySoft!
It is the easiest decoder to use and it generates 100% results!
You can download it from here for free " http://www.any-video-converter.com/download/ "
Once downloaded install it.
Then try to run it.
Click "Add File" tab at top right corner and add the DVD file you want to decode, select format you want to convert at top left corner.
Now Click the "Convert" tab and wait to complete the decoding procedure.
Set the "Output" folder, you can find decoded material their!
If you want to write the decoded dvd on a disk then you are going to need another software for DVD Shrinking, software named "Clone DVD 2" can serve this purpose, you can download and install it from internet for free!
Hope it helps!!
