Software for auto slicing bmp file
I have a number of bmp files that need to be sliced at different positions. I have tried adobe photoshop but the mass slicing feature does not work the way I want.
What I want is to define the slicing position of the images at first and then the software will proceed to slice according to the slicing parameters that I had set.
Is there a type of software that will start auto slicing bmp file with minimal user input?
Best Answer by Marvin M Calderon
Answered By 30 points N/A #169192
You can slice an Image into smaller segment in various ways.
This area can be selected according to percentage, pixel or arbitrarily.
As I noticed you need to arbitrarily splitting.
There are several slicing software You can look it out here.
The matter is, these are not free.
You can use this software for free
Hope, I helped you .
Regards
Robert T White
Answered By 50 points N/A #169193
Hello Coutu,
Splitting of images is possible and there are so many methods in order to do it. I will give you a link to download a software that are splitting images. This software allows you to cut images in different methods and design. You can check also it's features in the link before downloading it so that it will give you an idea about this kind of software.
https://software-download.name/slicing-an-image/download.html
Answered By 55 points N/A #169194
Hello Richard A Coutu,
               If you want to use a software that can help you in auto scaling the image file for you then you have to use the software names as Image viewer CP gold. That can help you in cutting and editing too dependent on the quality of your image. It is a handy software and not a tough one to use. You can also get the tutorial of that software in the below link. It can also provide you the facility of converting your files of images if you want that.
http://soft.udm4.com/downloading/auto_slicing_bmp_file/
