Software for Automatic Data Entry
Are there highly recommended softwares in the market that can enter numeric data in a simple excel sheet consisting of a regular (no formula or special formats) 1000 cells and 500 columns of existing database reports in HTML? Can anyone give me the details about it? Thank you.
Best Answer by Rheanne Scott
Answered By -5 points N/A #103315
There are some software available out there for entering data, but I don’t think that there are very accurate. There is a possibility that working with any kind of software, will double the work that you have to do. Because you need to verify what that software inputs in your excel sheet, and then if it’s not good then you will have to enter the data as you would from the beginning. I can recommend you some links like https://docparser.com/blog/data-entry-automation/ or https://www.kofax.com/. But if you search on Google you will probably find more software like those above, and then use whichever you think its best.
Answered By -5 points N/A #103316
Hi there,
There are many software that can be termed as automated data entry software. One of them is Kofax Capture that has the ability to capture all types of papers and electronic forms and documents and transforming them accurately into spreadsheets.
https://www.kofax.com/Products/Information-Capture
Another  very good software is Abbyy, that has the quality of having state of the art recognition that enable it to input the data accurately.
https://www.abbyy.com/en-us/flexicapture/how-it-works/
Answered By 0 points N/A #324743
You may also try Grooper’s data tools. It’s computer vision looks at data sources and, using AI, finds tables and where data should exist and can format it accordingly: https://www.bisok.com/grooper-data-capture-method-features/multi-pass-ocr/ It can also integrate with any data format, such as PDF or html: https://www.bisok.com/grooper-data-integration-platform/
