Wright
10 points
Posted on - 07/25/2011
I'm afraid there are people who idle install malicious programs on my computer. Looks like this is also a good idea to limit what programs can be installed.
So I want to ask is there any software that can block programs or files. Exe not found in the previous list that we have set? But it can also set the program on several clients PC.
candy
Software to block programs that are not listed in the list?
Hello Wright,
Yes there are many programs or software's that can block and prevent unwanted programs to run on your pc. They work as a barricade for those programs, and minimize their activity regarding running on your computer.
You can use windows defender program, which is very popular and well-known among the users and very effective regarding the safety of your computer from unwanted harms. It removes those harms by scanning the pc, helps to detect pop-up viruses, Malwares, spywares and harmful programs. Another program that is very popular is Mailwasher, a spamfilter software, very effective and efficient in removing harmful contents that are there in your pc.
You can Download it from the link.
You can download those applications from the links above.
There are other ways also for preventing the pc to get harmed. You can turn on the firewall option for your computer. It enables the system to check and if necessary block programs or contents that are harmful in nature and which may cause damage to your system. Check the link below:
Wright
10 points
I think Windows just for the antivirus, could actually be used to block unwanted programs. Thanks once again for the push!
