Software to call from bb offline
Sometimes I have to keep my black berry offline. Which supportive software is best to call to another cell phone while my bb going offline?
Hi, Coury!
By offline, do you mean you have no signal? If that is the case, you cannot make any calls or send text messages. Except emergency calls. But there are a couple of applications that you can use by just being connected to a wireless connection. Mainly VOIP (Voice-Over-Internet Protocol). Here is the link for the applications available for your device.
https://www.lifewire.com/voip-blackberry-3426390
Good luck!
Well, if your phone is offline, the best solution there is to contact your local phone service provider and inquire about the call divert and voice mailbox service. There is no software to resolve your concern, as this requires your an active service which can be provided only by your network.
