Software that can schedule my computer to shut down
Is there a software that can help me on how I can schedule my computer to shuts down on a specific time and date? It should be a automatic shut down. I need your suggestions. Thanks.
Yes it is possible and there are many software available for download. Download from the links below:
These are both freeware version.
Hi TIFAOUI SAID, because you didn't gave info about your OS, i give you sample to wake up PC basically on Windows
Wake up PC from BIOS
Restart Computer and go to BIOS Setup
Select “Power Management Setup” and enable “ PWRon/Resume by alarm” and set date alarm and time alarm and then press F10 to save your change and turn off your pc.
But not every computer have this BIOS feature. You can hibernate your system, then set up time to wake up.
Start > Programs/All Programs > Accessories > System Tools > Scheduled Tasks. Double-click the Add Scheduled Task, click Next. Select a program you'd like to run when your system wakes up, and schedule the task, Finish. After that, right click the task you just made > Properties > Settings tab, check Wake the computer to run this task, and click OK.
If your must login to your window system, you can disable login from Control Panel > User management.
