shaikot214
Posted on - 12/14/2012
I have a Mac laptop. I use its webcam frequently for chatting. But I want to capture some pages with the webcam. Is it possible to take still pictures by using this webcam? If it’s possible, can anyone please help me to find “Mac software webcam still pictures”?
If you know about any software like this, please explain how I will use it.
Software for capturing still photo with built-in webcam in Mac
Hi Shaikot214,
You mean you want to take pictures using your laptop webcam? You can use it still picture. There is software that can take picture of your screen. Its called screen capture or screen shots you can download it to your laptop you can use it once you want to take a picture of the person in the screen. You take picture to the an active window in your computer desktop.
Try this two links to download and install it to your laptop
https://www.thoughtco.com/screen-capture-mac-1702755
http://www.ducklink.com/p/free-screen-capture-tool-on-mac/
I hope I answer your question and I hope its helps you to solve your problem in your web cam about still pictures.
