Software Center error while changing the software
I have this Error created by the App-V Detection Methods. I made a small research on the Internet using the code Error shown below and nothing useful was found. Any solution for this Error ? What should I do to repair this ?
Thanks !
Unable to make changes to your software
There was a problem applying changes to the software. You can try again. Or, if the problem continues, the information that is shown in the following section can assist your help desk in troubleshooting.
Click OK to return to Software Center.
More information
The software change returned Error code 0x87D0032d (-2016410844)
OK
Answered By 590495 points N/A #179001
Check if you are using the latest version of Application Virtualization or App-V. If not and you are using an old version, try updating to App-V Service Pack 2. It is included in Microsoft Desktop Optimization Pack 2013 R2 [MDOP]. It is a suite of management and security technologies, and virtualization which is available for subscription. After updating to this Service Pack, check if it is already working.
In case you are already using App-V 5.0 Service Pack 2, try installing Hotfix Package 4 for Microsoft App-V 5.0 Service Pack 2. This hotfix improves the publishing and refresh performance in all App-V deployment situations such as VDI, RDS, and Traditional Desktop.
