Software for checking duplicate files
Hi! I just want to ask if anybody knows a certain program that could find out if there is any duplication in my folder files. I have two folders that are both containing music files in them. I wanted to see whether there is any file that exists in both folders. Is there any software which can do this? It is a large file so I would have headache if I do it manually. Do you think Windows utility can do this?
Best Answer by Clair Charles
Answered By 15 points N/A #104513
There are many softwares for checking duplicate files on the internet, some which you will need to download and install them on your computer to use them while some you can just use them online. Some of those softwares include the following:
The above-mentioned are just but a few. You can get a whole range of the duplicate finders to choose from, and all you have to do is to go to the search engine of your choice and search them from there.
-Clair Charles
Answered By -5 points N/A #104514
Hi there,
I am providing a link that will help you out in checking duplicate files.
Anti-Twin is a software application that matches files. It works in a way that it searches for duplicate copies on your hard disk drive. Any matching file that is found out can be deleted straightaway.
http://www.anti-twin.com/
I hope it helps.
